ghaddow
Ultrascale ISERDESE3 with edge timed DDR data
Can ISERDESE3 (Ultrascale Kintex) be presented with edge timed DDR data?
(or is it necessary to either (a) phase shift the DDR clock by 90 degrees in an MMCM/PLL, or (b) add an IDELAYE3 in time mode?)
sandrao
Community Manager
Community Manager
There are setup and hold time for the ISERDESE3 that needs to be met.
There is a clock alignment that is done in UltraScale automatically when you include the IDELAY : https://www.xilinx.com/support/answers/64743.html
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
sandrao
Community Manager
Community Manager
Sandy
