05-02-2017 08:26 PM
I’m implementing an RLDRAM3 interface using the RLDRAM3 MIG. The RTL simulation, synthesis, and implementation processes completed without error, but the following problems occurred after the FPGA program process:
CRITICAL WARNING: [Xicom 50-46] One or more detected MIG version registers have empty values: MIG properties will not be built.
Parameter Map Version: 0, Error Map Version: 0, Calibration Map Version: 0, Warning Map Version: 0
INFO: [Labtools 27-2302] Device xcvu190 (JTAG device index = 0) is programmed with a design that has 1 MIG core(s).
WARNING: [Labtoolstcl 44-130] No matching hw_ilas were found.
Referring to AR# 64923, I added the ’calibration_rld3.elf’ to the project. However, this problem has not been solved yet. Note that the ‘microblaze_mcs_rld3.bmm’ file does not exist in my source folder.
My platform and Vivado version information are as follows:
* Platform: Virtex UltraScale VCU110 Evaluation Platform (xcvu190-flgc2104-2-e)
* Vivado version: Vivado 16.4
Any advice is welcome. Thank you for your time.
05-04-2017 02:13 AM
Hi @jangbiemee
You can find the 2016.4 files here https://www.xilinx.com/member/forms/download/design-license.html?cid=0cb09bf1-1e8a-4be6-b337-884a2bfd8199&filename=rdf0338-vcu110-mig-c-2016-4.zip
05-02-2017 11:10 PM - edited 05-02-2017 11:11 PM
Hi @jangbiemee
Did you generate the RLDRAM IP following the steps in the below doc https://www.xilinx.com/member/forms/download/design-license.html?cid=a7a77853-c687-443a-956b-b1654c09e460&filename=xtp376-vcu110-mig-c-2016-4.pdf ?
This error is seen if the input clock or reset to the RLDRAM IP are not proper.
Are you adding RLDRAM IP XCI or DCP to the project?
05-03-2017 08:53 AM
Hi Deepika,
Thank you for your information.
BTW, where can I get the 'RDF0338 - VCU110 MIG Design Files (2016.4 C) zip' file? I've only found the 2016.3 version without the rld3_36b design on Virtex UltraScale Design Hub - VCU110 Development Kit.
Thank you.
05-04-2017 02:13 AM
Hi @jangbiemee
05-04-2017 08:21 AM
Hi Deepika,
The problem has been resolved. Especially, the 'example_design.xdc' file and 'Reference Input Clock Speed' information were helpful. Thank you very much.
