Visitor jangbiemee
Ultrascale RLDRAM3 MIG (Invalid core)
I’m implementing an RLDRAM3 interface using the RLDRAM3 MIG. The RTL simulation, synthesis, and implementation processes completed without error, but the following problems occurred after the FPGA program process:
CRITICAL WARNING: [Xicom 50-46] One or more detected MIG version registers have empty values: MIG properties will not be built.
Parameter Map Version: 0, Error Map Version: 0, Calibration Map Version: 0, Warning Map Version: 0
INFO: [Labtools 27-2302] Device xcvu190 (JTAG device index = 0) is programmed with a design that has 1 MIG core(s).
WARNING: [Labtoolstcl 44-130] No matching hw_ilas were found.
Referring to AR# 64923, I added the ’calibration_rld3.elf’ to the project. However, this problem has not been solved yet. Note that the ‘microblaze_mcs_rld3.bmm’ file does not exist in my source folder.
My platform and Vivado version information are as follows:
* Platform: Virtex UltraScale VCU110 Evaluation Platform (xcvu190-flgc2104-2-e)
* Vivado version: Vivado 16.4
Any advice is welcome. Thank you for your time.
Re: Ultrascale RLDRAM3 MIG (Invalid core)
Hi @jangbiemee
You can find the 2016.4 files here https://www.xilinx.com/member/forms/download/design-license.html?cid=0cb09bf1-1e8a-4be6-b337-884a2bfd8199&filename=rdf0338-vcu110-mig-c-2016-4.zip
Deepika.
Hi @jangbiemee
Did you generate the RLDRAM IP following the steps in the below doc https://www.xilinx.com/member/forms/download/design-license.html?cid=a7a77853-c687-443a-956b-b1654c09e460&filename=xtp376-vcu110-mig-c-2016-4.pdf ?
This error is seen if the input clock or reset to the RLDRAM IP are not proper.
Are you adding RLDRAM IP XCI or DCP to the project?
Deepika.
Visitor jangbiemee
Hi Deepika,
Thank you for your information.
BTW, where can I get the 'RDF0338 - VCU110 MIG Design Files (2016.4 C) zip' file? I've only found the 2016.3 version without the rld3_36b design on Virtex UltraScale Design Hub - VCU110 Development Kit.
Thank you.
Hi @jangbiemee
Deepika.
Visitor jangbiemee
Hi Deepika,
The problem has been resolved. Especially, the 'example_design.xdc' file and 'Reference Input Clock Speed' information were helpful. Thank you very much.
