loicm88
Ultrascale+ SLR crossing
I am targetting a xvu13p ultrascale+ fpga which has a 4 SLRs architecture.
I have a main clock at 350 MHz, and I am seeing big timing violations when crossing SLRs.
Is there any strategy for clocking through SLRs and for logic placement advised by Xilinx?
vemulad
Hi @loicm88
You can create SLR based pblocks for better results.
You can group all timing critical paths which are crossing SLR in to a pblock and place it in a single SLR.
Deepika.
sandrao
Community Manager
Community Manager
The UFDM is a good read for this topic : https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug949-vivado-design-methodology.pdf
Specifically the section Designing with SSI Devices and SSI Technology Considerations. It has some details on SLR crossings.
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
loicm88
Thanks Sandrao, I'll take a look!
vemulad
Hi @loicm88
Deepika.
ADGio
and thank you for the link. I have a doubt.
I'm using a Virtex Ultrascale+ device, with 3 SLR.
At present, I use only one SRL, and the system Works, although some congestion is observed.
Due to the complexity of the design, and to the future evolution roadmap, I'm interested in spreading the design over different SRLs, in order to use better the resources.
The UFDM, at page 258, suggests:
- to create 2xSLR pblocks
- to create 2x SLR crossing pblocks
- use sufficient pipelining between the major hierarchies is required to ease global placement
If I understand correctly, I should :
1. "divide" the design elements between the SLRs, and assign each to a SLR Pblock. This división should try to minimize the crossSLR paths.
2. to add pipeling elements between the elements
As I'm usign Axi4stream interfaces, I understand the correct pipeling elements are the Axi Slice register in SLR crossing configuration.
My questions:
1. how many Axi Slice Register (with SRL crossing) should I use for each SLR crossing?
2. where should I to put it/them?
For example;
- only one, in the source Pblock
- only one, in the destination Pblock
- a pair of them, one in the source and the other in destination pblocks
- only one , in SLR-crossing Pblocks.
The document is not clear about it. Can anyone help me?
Thank you
regards
