Unable to add zynq ultrascale IP in Vivado IP Integrator
I have been following the Xilinx embedded design tutorial (UG1209).
When I press the add IP (+) button, and type in Zynq, the only IP visible in the drop down is Zynq ultrascale + VCU.
I am unable to figure out from where Zync Ultrascale + MPSoC IP can be added.
Edit: More info: Vivado 2018.2, Zynq Ultrascale+ MPSoC ZCU102-Evaluation board, node-locked licence that came with the board purchase.
TIA
Anoop
Re: Unable to add zynq ultrascale IP in Vivado IP Integrator
Hi @mnanoop2014,
Can you double check in your project settings if the board ZCU102 is correctly selected (as in the image below)?
I suspect it might be set to a VCU instead.
Andre Guerrero
Product Applications Engineer
Mnanoop2014,
Which Zynq ultrascale+ device have you selected in Vivado? What version of Vivado? What vivado license package?
T
Info updated :)
Hi @mnanoop2014,
Andre Guerrero
Silly me! I had not explicitly "clicked" on the board that appeared when I selected "Zynq Ultrascale+ ZCU102" from the drop down in "select board" screen, since that was the only board that popped up and there was neither a selection check box nor multiple entries.
