Observer sergio
Use of IP Core with no license in Vivado
I was wondering if it is possible to use one the Xilinx IP Cores, let's say Gamma Correction, without license in order to run synthesis and simulation? Would I get synthesis errors due to I do not have the license?
Is also possible to run implementation and bitstream generation without license?
It is clear for me that at the end I have to buy the license, but I do not know if it is possible test the IP for free.
Thank you very much.
Kind regards,
Sergio
Scholar dpaul24
Re: Use of IP Core with no license in Vivado
@sergio,
I can only comment in a general way.
Almost all Xilinx cores can be used in simulation. If some special license is required, then the Synth stage run will inform you. There are some cores in which a hardware evaluation license is available. With that license you can generate a bit stream which will run for a couple of hours and then cease to function.
FPGA enthusiast!
All PMs will be ignored
Scholar dpaul24
@sergio,
FPGA enthusiast!
Observer sergio
Hi dpaul24,
thank you very much. Now it is clear for me.
Kind regards,
Sergio
