Visitor yorgzero
Using the bitstream AES encryption block for user AES encryption/decryption
The Ultrascale product suite includes and AES block to decrypt the FPGA bitstreams. It does not seem like that the bitstream encryption AES block can be used by the FPGA logic or for any other purpose than bitstream decryption. Is that correct?
Thanks in advance
YorgZ
Observer yufei.leung
Re: Using the bitstream AES encryption block for user AES encryption/decryption
It can be used from Linux after boot-up.  Refer to:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/64749783/ZynqMP+AES+Driver
Starting from Xilinx SDK version 2018.3, it is available under the list of Hardware crypto devices in the menuconfig.
You also need to enable the User-space interface for symmetric key cipher algorithms in the menuconfig.
Edit your Device Tree to include the zynqmp_aes device.
Using the Device Key:
  • If you try to use the Device Key as your key source, and it errors out with this message:
    • zynqmp_aes zynqmp_aes: ERROR: Wrong KeySrc, enable secure mode
  • Then it's a restriction imposed by the PMUFW. Look in the PMUFW code, and find this file, and look for the function:
    • pmufw/zynqmp_pmufw_bsp/psu_pmu_0/libsrc/xilsecure_v3_2/src/xsecure.c  XSecure_AesOperation()
    • Edit this snippet of code to allow yourself to use a key source other than the KUP key:
      #ifndef XSECURE_TRUSTED_ENVIRONMENT
         if (AesParams->KeySrc != XSECURE_AES_KUP_KEY) {
            Status = XSECURE_DEC_WRONG_KEY_SOURCE;
            return Status;
      #endif
    • Then just re-compile the PMUFW
            return Status;
      #endif
Visitor yorgzero
Hello Yufei,
Thanks a lot. That answers my question. I wanted to know that it was possible so that is great.
Just to make sure I understand correctly. This assumes Linux has boot up, in the Zynq ARM CPU and then the AES can be addressed from inside the FPGA programmable logic via the AXI bus. Is that correct? Or is it just available to the ARM CPU drivers?
YorgZ
The procedure I referred to is using the AES HW from the ARM CPU (the Cortex A53), after booting up in the Linux.
I'm not sure if the FPGA can use the AES HW via AXI bus.  I have to admit that overall I am not familiar with the FPGA-side of things, since I've mainly worked on the PS-side.
Visitor yorgzero
Hi Yufei,
Thanks, that is fine, so far I didn't find anything suggesting that it is possible in the docs. So, I will assume that is not supported.
YorgZ
