bowen_fu
VCU108 Board Tandam PROM
I generate PCIe example following PG156. In page 79 of the document, it sas VCU108 is supported to implement Tandem PROM.
I use Vivado v2015.4.2, but it still give the error when generating bitstream: [Vivado 12-4165] Tandem Configuration bitstream generation is not supported for part xcvu095-ffva2104-2-e-es2.
Is the document not telling the truth?
Thanks!
pratham
@bowen_fu Let me check and get back to you on this. I think it is supported but since you are getting an error, let me reconfirm
-Pratham
syedz
@bowen_fu,
Check page number 7 in release notes of Vivado 2015.4:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf
--Syed
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
pratham
-Pratham
bowen_fu
Thanks pratham
