nmurthy
What are the Memory recommendations to Generate RFSOC RDF0476 reference Design. While trying in 16GB RAM with i7 Processor Laptop the system is getting hanged.
nmurthy
There is bug with vivado version 2018.2 OOC, the reference design hangs while doing OOC. which is generated normally in 2018.3 version Vivado
travisc
Below is a link to the normal memory usage for different devices.You might be on the edge depending on the device you are targeting. Looks like around 10-17gb depending on density.
https://www.xilinx.com/products/design-tools/vivado/memory.html
nmurthy
