What's the difference between -1L and -1LV?
Hi All,
I found there were two similar part number:
xcku115-flvd1517-1L-i
xcku115-flvd1517-1LV-i
what's the difference between -1L and -1LV?
These are the same parts, the difference is the voltage as @florentw has clarified. The reason we have the -1L and -1LV in the tools is to differentiate between the VCCINT voltages as the performance will depend on the VCCINt voltage.
To get the reduce static power the VCCINT should be @ 0.72v but there will be a reduced performance as listed in the data sheet.
@ 0.85v you will improve performance but have no reduction in static power.
Hi @araongao2015,
The answer is in DS922 p17:
It just depends on Vccint.
Florent
Florent
refer product selection guide page number 4
https://www.xilinx.com/support/documentation/selection-guides/ultrascale-fpga-product-selection-guide.pdf
Thanks and Regards
Balkrishan
@balkris,
You link does not explain the L or LV... the L and V letter correspond to the package in the slide, not to "Low Voltage devices"...
Florent
 @florentw you can find difference in attached table . The only difference in in minimum and average operating voltage
Thanks and Regards
Balkrishan
@balkris,
Yes, and this difference is coming from which Vccint they are operated at... as per my first message...
Florent
Thanks, @florentw , @jheslip
