Visitor jwright
XCVU37P-FSVH2892 Thermal Model
This request is similar to the one I submitted earlier regarding the thermal model for XCZU29DR-1FSVF1760I. I need the same info for the XCVU37P-1FSVH2892E. Where can I find the details for creating a "Delphi model" and "Detailed Model" for XCVU37P-1FSVH2892E as mentioned in xapp1301-mechanical-thermal-design-guidelines.pdf?
Any help is appreciated.
Re: XCVU37P-FSVH2892 Thermal Model
@jwright  Since you are using Solidworks, we don't have a Thermal model for the same. However we do provide the thermal resistance table (under NDA) when requested through an SR using which you can build your own model in Solidworks.
Having said that, we did receive your request for this through an SR from our FAE and you should be receiving the above file soon.
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
@jwright  You can download the DELPHI model for XCVU37P-1FSVH2892E here
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/device-models/package-thermal-models/utrascale-plus-fpgas.html
If you need a Detailed model, please approach your Xilinx FAE or Distrubutor FAE who can open an SR for you and get you the models. These detailed models are shared only under NDA.
Having said that, if you are at the initial stage of your Thermal solution design,  start off with the DELPHI model as you may need to do various iterations and then use the Detailed model to fine tune and finalize your thermal solution.
- Giri
Visitor jwright
Note:  we use SolidWorks FlowSimulation.  Where can I find the details for creating the XCVU37P-FSVH2892 DELPHI thermal model?
Hi @jwright,
Please check this help or ask Solidworks to see if the delphi model is supported or created in solidworks, or detail model is required.
Simon
Visitor jwright
The pdml file is Flotherm specific, and the tzr file is Icepak specific.  Solidworks cannot open either one.
- Giri
Visitor jwright
Potentially, I can also use the detailed thermal model for this part - we may gain access to Icepak.  I've requested our Xilinx FAE to open a SR for the model.   Do you know when it will be available?
