rah123
XCVU440 Boundary Scan Register Length mismatch with BSDL file
The BSDL file for the XCVU440, package FLGB2377, specifies a boundary scan register length of 5487 bits.  However, some basic testing shows that data scanned in to TDI comes out of TDO after only 5472 TCK clock cycles, indicating a boundary scan register length of 5472 bits.  This was with the SAMPLE instruction loaded.
I suspect this is most likely due to the BSDL file being incorrect, so has anyone ever successfully used boundary scan with the XCVU440 and this BSDL file?
Rob
pratham
@rah123 I think issue has been resolved when BSDL file of ES device used . Issue here was using production device bsdl file with the ES device.
-Pratham
pratham
@rah123 Yes, there is issue with the bsdl file. I think you have already created SR on this which would help you to get the correct bsdl file.
-Pratham
pratham
-Pratham
