pablo123@
XCZU25DR FSVE1156 RFSoC Power Pins
I am trying to design a power supply for the XCZU25DR FSVE1156 RFSoC. Where can I find current ratings for power pins of this chip? I have been looking at the DS926 and found the nominal voltage values of power pins.
Any help is much appreciated.
Thank you.
Paul
gnarahar
pablo123@  You will need to use Xilinx Power Estimator (XPE) spreadsheet or Report_Power of Vivado based on which stage of the design cycle you are in.
If you are in the early stages, use XPE from here https://www.xilinx.com/products/technology/power/xpe.html
Take a look at this thread that answers a similar query https://forums.xilinx.com/t5/UltraScale-Architecture/Ultra-scale-plus-power/m-p/940671 and has links on usage of XPE and Vivado Report_Power
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
gnarahar
- Giri
