vilas@s
XCZU47DR-2FFVE1156 maximum frequency for AC_PDN analysis
Hi Team,
In one of my design i am using Zynq ultrascale device manufacturer part number "XCZU47DR-2FFVE1156". I need to perform the board lelvel decoupling analysis considering the decoupling capacitors in the power plane to meet the PDN within the specified limit.
Here, i have doubt what is the maximum frequecny level need to select for the AC_PDN analsys.
Vilas Kumar S
zhendon
Community Manager
Community Manager
impedance target and frequency range for ADC/DAC is required as below in UG583image.png
For other digital power rails, the cutoff frequency can be roughly upto 10-20Mhz. I think the median range 15Mhz would be good for your design.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
