jorgitog1
XRFdc_TileStatus: PowerUpState and TileState
Is there a reference for how to interpret the values of PowerUpState and TileState members of the XRFdc_TileStatus structure?
Thanks for your help.
klumsde
You can look in appendix C of PG269.
This details the driver data structures and the API calls.
PowerUpState is normally returning a 1 when the tile is powered up and running
Then TileState reflects the state that the IP start up state machine is in. 0xF for complete, 0x6 for clock detect for example.
klumsde
jorgitog1
Thanks a lot klumsde !!!
