iqbalr
XTP427 Schematic Review Checklist - Error running the worksheet?
Hi all,
I seem to be hitting an issue with the XTP427 UltraScale+ Schematic Review checklist. I keep receiving an error dialog when running any commands (such as 'Create a new checklist') in the worksheet:
"Compile error in hidden module: Module <#> [...] This error is incompatible with the version, platform, or architecture of this application. Click 'Help' for information on how to correct this error."
Needless to say, the help page is blank. I've tried upgrading from Office 15 (2013) to Office 16 (2016), but that hasn't resolved the issue. I've also tried saving out to alternate formats (.XLSM, .XLSX, etc.) but that hasn't worked either.
I'm wondering if it's stemming from using 32-bit Office on 64-bit Windows... but I would hope the worksheet would be more robust than that.
Any ideas on how to resolve this?
Thanks in advance!
gnarahar
@iqbalr Sent you an email with a version of file. Let me know if that works for you.
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
iqbalr
FYI - that error is preventing the commands from running, so the workbook is effectively dead... can't see any way to use this so far.
gnarahar
- Giri
iqbalr
vanlandingham10
@gnarahar I am now having the same issue. Can you send me an email with the version that worked on office15. Thanks.
gnarahar
@vanlandingham10 Done
- Giri
raytheon.xilinx
@gnarahar I also had the same issue for Ultrascale series (XTP344). Is it possible to kindly provide one version file to fix this issue.
y910129
I am having the same issue. Can you send me an email with the version that worked on office16. Thanks.
I'm having this same issues...Can I please be provided the correct version of the file
jflo
gnarahar
jacqueline@epiqsolutions.com  Sent you the file
- Giri
hill
I'm always meeting with the same problem with XTP427 on the WIN10/OFFICE 2013 64BIT.
Can you please send me a copy?
rjlagnea
I am experiencing the same problem as all of the others in this discussion, could I get a copy of the updated file as well?
nhulst
I am having the same issue.  I am stuck on Excel 2013.  Could I please get a copy of the updated spreadsheet?
gnarahar
@nhulst Sent it to you over email.
- Giri
nhulst
It is working fine.  Thank you!
AlSc
Same problem with "XTP427 (v1.10) November 13, 2020"
Office 2016 32bit on 64bit Windows.
Would also like to try the copy if possible.
