cclinrichard
ZCU 111 Non-MTS 8*8 example
Hi, I am following the tutorials on ZCU111 to learn the non-MTS mode
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57573648/Non-MTS+Design+8x8
However, when I follow the tutorials and start generating the signal from the DAC, it appears the following error message:
ERROR: LocalMemTrigger EXECUTE
invalid: args Design doesnot support non-MTS mode
I was wondering if anyone has faced or know the error before and give me some hints/tips/guidance on it.
Thanks in advance
CC
zhendon
Community Manager
Community Manager
Hi @cclinrichard
default design loaded is non-MTS design and you have to change to MTS design first to run MTS test as below.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
zhendon
Community Manager
Community Manager
Hi @cclinrichard
