ZCU 111 teraterm RF DC
I am trying to connect the zcu111 board to the host machine using tera term but i cannot successfully connect.
I am following the ZCU111 RFSoC RF Data Converter Evaluation Tool Getting Started Guide from https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57606309/ZCU111+RFSoC+RF+Data+Converter+Evaluation+Tool+Getting+Started+Guide
thank you
Hi @shtsao
Looking at the  terminal prints , it seems  baud rate is not  set correctly ?
Can you please check if this is set to "115200"?
Additionally I presume your device is booting from SD card , Is the mode pins and SD card content correct as specified in wiki page?
