Observer suramyag1
ZCU102: Ubuntu Core`
I wanted to run Ubuntu Core on ZCU102. I've followed the following documentations:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841937
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842112
However, both of them need PCIe disabled, which is required. I then found https://www.xilinx.com/support/answers/66636.html which seemed helpful.
The link to Ubuntu 14.04: http://cdimage.ubuntu.com/ubuntu-core/releases/14.04/release/ubuntu-core-14.04.3-core-arm64.tar.gz has become invalid. I tried with Ubuntu 16.04 (http://cdimage.ubuntu.com/ubuntu-base/releases/16.04/release/), but on using the chroot command:
chroot /chroot_mnt
it throws the following error:
chroot: can't execute '/bin/sh': Exec format error
On searching for the error, it seems that this occurs when a 32 bit system is run on a 64 bit system. However, both the petalinux (created for ZCU102) and Ubuntu Core (I'm using the amd64 core, as that's what was described in AR #66636) are 64-bit.
What could be the problem?
Thanks in advance.
Re: ZCU102: Ubuntu Core`
The ZCU102 uses an ARM 64-bit processor not an AMD 64-bit processor.
You must use the arm64 core not amd64 core
Observer suramyag1
I found the 14.04 version here:
http://cdimage.ubuntu.com/ubuntu-base/releases/14.04/release/
It gives the same error as the 16.04 version.
