damen_red
ZCU111 ADC Capture sample depth
Hello, I am trying to perform a capture of a modulated signal similar to the one in this example from Xilinx:
https://www.xilinx.com/video/events/rfsoc-gen3-rf-data-converter-5g-nr-performance.html
I am using the ZCU111(with DC UI v1.6), this example uses the ZCU208(with DC UI v2.2). I recognize that these are two different sets of hardware/software. My question is, am I able to do a capture similar to this one? I don't see an option to export when right clicking in the ADC window, and the export function from the main menu only gives me about 32k of data, which is not enough for me to evaluate one frame. How can I achieve this with the ZCU111 out of the box?
damen_red
Yes, this was exactly my issue, thanks!
klumsde
In the evaluation design on ZCU111 you have two capture memory options.
If you can only get 32K in IQ mode then it is most likely because you are using the BRAM to capture the data.
In this case you need to change the capture memory to DDR.
The maximum sample size allowed is dependent on the design. The design return an error or a
warning if the maximum size is exceeded. The DDR mode supports up to 128M real samples per
channel, but has limitations on the data rates. This limitation on the data rates comes from
different aspects of the software design and not from the Zynq UltraScale+ RFSoC.
should give you 64M capture for these IQ modes
damen_red
klumsde
OK can you please Mark the reply as the solution so others can find it useful
damen_red
Now I see that the DAC output seems to be a different format when switching to DDR, or at least to me appears that there is some non-coherence in the sine wave. Is there anything else I need to know when switching to DDR capture?
klumsde
Can you share the spectrum here?
Can you also share the settings for the DAC tile, what is the data rate of the DAC input bus here.
Try changing the interpolation factor here to see if it cleans it up. if that happens then the problem is with the DDR data rates.
damen_red
Here are two spectrum captures hopefully depicting my issue. The first one is from a fresh bring up of the tool with default configuration and 200MHz tone(which is the default). Only thing I do is "generate" and "acquire". The default being BRAM, I then switch to DDR and hit "generate" and "acquire" again, resulting in the second spectrum.
BRAM CaptureBRAM CaptureDDR CaptureDDR Capture
klumsde
Hi @damen_red
Increase your decimation factor here.
I expect this is an issue with the BW of the DDR interface.
Keith
