ZCU111 Board: RF ADC PL VHDL/Verlog examples?
I am about to purchase a ZCU111 evaluation board. Where can I find HDL code that a PL design with interface to RF ADC and DAC tiles? Thanks.
Re: ZCU111 Board: RF ADC PL VHDL/Verlog examples?
Hi @gatlinsystems
We provide the prebuilt images and tcl scripts to build some designs which are avaiable here
https://www.xilinx.com/products/boards-and-kits/zcu111.html#documentation
Apart from this you can configure the IP as per configuration intended and generate the example design,
please refer to example design section in product guide
https://www.xilinx.com/support/documentation/ip_documentation/usp_rf_data_converter/v2_2/pg269-rf-data-converter.pdf
Hi @gatlinsystems
Hello @gatlinsystems
Is @pthakare  answer above enough for you ?
If yes could you please mark this thread as a solution so other forum user can learn from your experience ?
Thank you
Leo
Thanks for the information. I downloaded the files that you suggested. They seem to have enough details on how to proceed. Once I get the ZCU111, I will apply the direction on these files and hopefully the direction will be helpful. I will post my findings at that time. Regards.
