xilinxer
ZCU111 DAC TVALID unconnected
We are working with a ZCU111 and instantiated multiple DACs in the FPGA fabric (Vivado 2019.2, RF Data Converter 2.2).
Everything works so far and we are able to generate signals, however, there is an issue with the TVALID signal to the DAC's.
According to the specification and PG269 Table 113, we assumed that de-asserting TVALID would result in no output (except noise) on the DAC, however, the data provided on the TDATA signal is still replayed.
Digging deeper, it turns out that the TVALID signal is not connected, and it seems like the connection is missing in the RFDC module, therefore being optimized away. This can be seen in the netlist already after synthesis.
In Vivado, the following log message is displayed:
"[Synth 8-3331] design ps_system_rfdc_0_block has unconnected port s00_axis_tvalid"
Is it expected behaviour that this signal is unconnected?
klumsde
TVALID is not used in the IP
klumsde
