jyb-xiphos
ZCU111 Evaluation User Interface - MTS error
I am currently in possession of a ZCU111 evaluation board and I have installed the "RF Data Converter Evaluation User Interface (TRD v1.7)".
When I choose the MTS bitstream and "Apply" it on the ZCU111, I get the following result (PLL locking, no error...):
However, if I tried to "generate" a waveform from DAC0 (which usually works in non-MTS mode), I get the following error message:
The message seems to indicate that for some reason the GUI still consider the bitstream loaded as being the non-MTS one. Is there a step I have not followed properly or is this an issue with the evaluation UI?
Thank you for your help
vatsalt
Please refer to below Xilinx Wiki page for detailed instructions on zcu111 MTS design.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57803102/MTS+Design+8x8
Best Regards,
Vatsal
vatsalt
Best Regards,
Vatsal
klumsde
can you show how you're trying to load the waveform into the DAC?
Is this after MTS?
jyb-xiphos
Hi Vatsalt,
Following the instructions you shared (changing the GUI in MTS mode) did the trick. Thank you for sharing the link.
