ZCU111 Generate Data in PS and send to PL Rf data Converter
Hello all,
I wrote a program using the PYNQ framework to generate some custom modulated data. I would like to send that data from the PS to the PL Rf data converter to be transmitted out. I was wondering if there was existing IP that does this, or if someone could help to point me in the right direction of where to get started. I am using the ZCU111. I am very new to FPGA development and Vivado so I am having some trouble on where to begin.. I have seen some other examples of IP that will generate the data inside PL and send it to the rf data converter, but nothing that allows one to generate data on the PS side to be transfered to memory and then to the Rf data converter.
Thank you!
S. T.
Community Manager
Community Manager
Hello
It seems that you are looking for the solution to use PYNQ with ZCU111 board.
You may refer to below link and it is an open source project to run PYNQ on ZCU111 board.
https://github.com/Xilinx/PYNQ_RFSOC_Workshop
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
To add to this question, I have found an example of the PYNQ-Z1 ADC-DAC code to use the overlay to write data to be sent out. I can't seem to find the base overlay file for the ZCU111. Does this exist?
Community Manager
Community Manager
Hello
Thank you!
hi,
I also can't seem to find the base overlay file for the ZCU111.
when i import BaseOverlay, it was that ModuleNot foundError: No module named 'BaseOverlay'
how do i get it?
