ZCU1285/ZCU216 usage questions
I am new to this field, and our group is trying to find the XILINX FPGA to help our chip measurement.
We are targeting one of the FPGAs (ZCU1285/ZCU216) for our measurement setup and have some questions that hope to be clarified before we make the final decisions.
1) Both of them provide memories (2GB-64bit vs 4GB-64bit), are they enough to support for high number of fft points processing?
2) In both boards, is there any way to synchronize 16 ADC/DAC?
3) To connect 16 ADC/DAC, which connector should we use to interface between the XILINX board and our test PCB? I do see the accessories include the SMA cables, but I do not see the connector on board.
Please kindly advice. Any comment is helpful for us.
Can you request access to the lounges for these boards.
https://www.xilinx.com/member/zcu216.html
https://www.xilinx.com/member/zcu208.html
There is an RF Data Converter Evaluation design for each board.
The documentation and the known issue can cover the details of the DDR design for larger FFTs
There is support for Multi-Tile Synch and the boards also support various connectors including a Balun card that comes with the kit.
