jcbrackett123
Zync Ultrascale+ OSERESE3 Pulsewidth Timing Errors
I have an OSERDESE3 (migrated from OSERDESE2) design that is giving me pulsewidth errors.
    u_oled_oserdes : OSERDESE3
      generic map (
        DATA_WIDTH       => 8,
        ODDR_MODE        => "TRUE",
        OSERDES_D_BYPASS => "FALSE",
        OSERDES_T_BYPASS => "TRUE",
        SIM_DEVICE       => "ULTRASCALE_PLUS",
        SIM_VERSION      => 2.0)
      port map (
        OQ     => s_OLED_pin(i),
        T_OUT  => open,
        CLK    => Clk_In_4x,
        CLKDIV => Clk_In_1x,
        D(0)   => s_OLED_To_Ser_Byte(i)(7),
        D(1)   => s_OLED_To_Ser_Byte(i)(6),
        D(2)   => s_OLED_To_Ser_Byte(i)(5),
        D(3)   => s_OLED_To_Ser_Byte(i)(4),
        D(4)   => s_OLED_To_Ser_Byte(i)(3),
        D(5)   => s_OLED_To_Ser_Byte(i)(2),
        D(6)   => s_OLED_To_Ser_Byte(i)(1),
        D(7)   => s_OLED_To_Ser_Byte(i)(0),
        RST    => Reset_1x,
        T      => '0');
Clk_In_4x is 340.2 MHz and Clk_in_1x is 85.05MHz.  there is no reason for pulsewidth errors to occur, both clocks come from the same MMCM and are generated from a 216MHz clock.  The V7 design (OSERDESE2) used the same method and rates.
timing report with errors
Check TypeCornerLib PinReference PinRequiredActualSlackLocationPin
Max SkewSlowOSERDESE3/CLKDIVOSERDESE3/CLK2.392.50-0.11BITSLICE_RX_TX_X0Y47u_oled_sxga096/oled_serializers[1].u_oled_oserdes/CLKDIV
Max SkewSlowOSERDESE3/CLKDIVOSERDESE3/CLK2.392.49-0.10BITSLICE_RX_TX_X0Y45u_oled_sxga096/oled_serializers[3].u_oled_oserdes/CLKDIV
Max SkewSlowOSERDESE3/CLKDIVOSERDESE3/CLK2.392.49-0.10BITSLICE_RX_TX_X0Y43u_oled_sxga096/oled_serializers[4].u_oled_oserdes/CLKDIV
Max SkewSlowOSERDESE3/CLKDIVOSERDESE3/CLK2.392.49-0.10BITSLICE_RX_TX_X0Y39u_oled_sxga096/oled_serializers[2].u_oled_oserdes/CLKDIV
Max SkewSlowOSERDESE3/CLKDIVOSERDESE3/CLK2.392.47-0.08BITSLICE_RX_TX_X0Y41u_oled_sxga096/oled_serializers[0].u_oled_oserdes/CLKDIV
Why am i getting pulsewidth errors?
sandrao
Community Manager
Community Manager
Hi @jcbrackett123
The skew requirement is a new requirement in UltraScale (was not previously in 7 Series).
If you are missing the skew requirement there are details of how you can try to workaround it  in this AR : https://www.xilinx.com/support/answers/67885.html
The first step is to use one MMCM output for both CLK and CLKDIV and use two BUFGCE_DIV with one to divide for the CLKDIV, this will remove the phase error from the MMCM in the timing, its roughly around 110ps so with the snippet below you are missing the skew by about 110ps so that may be enough to met the skew requirements.
If not there are other steps in the AR on setting constraints to improve the skew between the two clocks.
Sandy
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
jcbrackett123
To me it seems like vivado (2018.3) is treating the OSERDESE3 as SDR when it is set up to be DDR.  These signals also throw setup errors from the register to the oserdes.  It has errors going from 1x clock (85.05MHz called s_video_clock_4x_gen) to the 4x clock (340.2MHz called s_video_clock_16x_gen) on the oserdes
NameSlackLevelsRoutesHigh FanoutFromToTotal DelayLogic DelayNet DelayRequirementSource ClockDestination ClockExceptionClock Uncertainty
Path 327-0.40011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[1][2]/Cu_oled_sxga096/oled_serializers[1].u_oled_oserdes/D[5]0.660.130.522.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 328-0.40011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[1][6]/Cu_oled_sxga096/oled_serializers[1].u_oled_oserdes/D[1]0.610.140.472.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 329-0.38011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[2][6]/Cu_oled_sxga096/oled_serializers[2].u_oled_oserdes/D[1]0.610.130.472.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 330-0.37011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[1][7]/Cu_oled_sxga096/oled_serializers[1].u_oled_oserdes/D[0]0.610.130.472.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 331-0.37011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[3][6]/Cu_oled_sxga096/oled_serializers[3].u_oled_oserdes/D[1]0.610.130.472.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 332-0.37011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[4][3]/Cu_oled_sxga096/oled_serializers[4].u_oled_oserdes/D[4]0.590.130.452.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 333-0.37011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[4][6]/Cu_oled_sxga096/oled_serializers[4].u_oled_oserdes/D[1]0.600.130.472.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 334-0.35011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[3][3]/Cu_oled_sxga096/oled_serializers[3].u_oled_oserdes/D[4]0.600.130.472.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 335-0.35011u_oled_sxga096/s_OLED_To_Ser_Byte_reg[4][7]/Cu_oled_sxga096/oled_serializers[4].u_oled_oserdes/D[0]0.600.130.472.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
Path 336-0.34012u_oled_sxga096/s_OLED_To_Ser_Byte_reg[0][4]_replica/Cu_oled_sxga096/oled_serializers[0].u_oled_oserdes/D[1]0.620.140.482.94s_video_clk_4x_gens_video_clk_16x_gen 0.21
sandrao
Community Manager
Community Manager
Hi @jcbrackett123
The problem is this line in the code
As you are not trying to use the OSERDES as an ODDR the ODDR_MODE should be FALSE.
From UG571
If you set the ODDR_MODE        => "FALSE", this should resolve your timing issues.
Sandy
Sandy
jcbrackett123
I am using the OSERDES as a ODDR.  I am serializing 8:1 which means you have to put it in ODDR mode.
sandrao
Community Manager
Community Manager
Hi @jcbrackett123
ODDR means 2:1.
As you are using 8:1 that is an OSERDES not an ODDR. In UltraScale all OSERDES are in double data rate there is no DATA_RATE attribute.
You need to set the ODDR_MODE = FALSE unless you are trying to use the ODDRE1 primitive.
Sandy
Sandy
jcbrackett123
Thank you for the clarification.  However this does not fix the pulsewidth errors.  I have verified in the implemented design that the properties on the OSERDES components have ODDR_MODE = FALSE
NameValue
BELBITSLICE_COMPONENT_RX_TX.OSERDES
BOX_TYPEPRIMITIVE
CLASScell
DATA_WIDTH8
FILE_NAMEC:/projects/bino_fw/build/envgb_top/envgb_top.edif
INIT1'b0
IS_BEL_FIXEDfalse
IS_BLACKBOXfalse
IS_CLKDIV_INVERTED1'b0
IS_CLK_INVERTED1'b0
IS_DEBUGGABLEtrue
IS_LOC_FIXEDtrue
IS_MATCHEDtrue
IS_ORIG_CELLtrue
IS_PRIMITIVEtrue
IS_REUSEDfalse
IS_RST_INVERTED1'b0
IS_SEQUENTIALtrue
LINE_NUMBER502450
LOCBITSLICE_RX_TX_X0Y41
NAMEu_oled_sxga096/oled_serializers[0].u_oled_oserdes
ODDR_MODEFALSE
OSERDES_D_BYPASSFALSE
OSERDES_T_BYPASSTRUE
PARENTu_oled_sxga096
PRIMITIVE_COUNT1
PRIMITIVE_GROUPI/O
PRIMITIVE_LEVELLEAF
PRIMITIVE_SUBGROUPSERDES
PRIMITIVE_TYPEI/O.SERDES.OSERDESE3
REF_NAMEOSERDESE3
REUSE_STATUS
SIM_DEVICEULTRASCALE_PLUS
SIM_VERSION2.00
SLR_INDEX0
STATUSFIXED
sandrao
Community Manager
Community Manager
Hi @jcbrackett123
Sandy
Sandy
jcbrackett123
Sorry for the delay.  I had to try a couple different things AR# 67885 suggests in order to close the errors.  I am still work on locking down the timing so its consistant but what it suggested did work in the end.  Thanks for you're help.
