Zynq UltraScale+ MPSoC Register Reference additional info
Hi all,
I'm trying to figure out how to use internal registers in the DDR-PHY skipping controller. A lot of registers are present but no additional documentation on usage.
Is possible to send a single command to the memory using these registers?
Tks, Antony.
Community Manager
Community Manager
Re: Zynq UltraScale+ MPSoC Register Reference additional info
Might be useful link for you : https://www.xilinx.com/html_docs/registers/ug1087/ug1087-zynq-ultrascale-registers.html
Sandy
Yes, this list is the starting point but the info about usage are not enough.
How to use PHY registers excluding DMC? What about data transfer? Can I use PHY also for data and what are the buffers to store data if any?
Usage is not explained especially for DMC interaction.
