10-26-2020 07:44 AM
I am conducting a thermal analysis involving the Zynq UltraScale+ RFSoC ZCU111 Evaluation Kit, Part Number: EK-U1-ZCU111-G; specifically the RFSoC (XCZU28DR-2FFVG1517E). I am looking for thermal information on the RFSoC. Either a thermal map of the hot spots or a layout of the components inside the RFSoC with callouts for power consumption from each component. Is that data available?
10-26-2020 09:53 AM
Have you seen the XPE spreadsheet: https://www.xilinx.com/products/technology/power/xpe.html
You can analyze the power contributions based on your anticipated design (targeted the ZU28DR RFSoC) utilization and play what-if scenarios. As usual for a programmable device, the dissipated power will be heavily dependent on your design.
more info here:
Admittedly, that's more for the central component here and not a board-level view. But it is likely the first order main contributor here and the best place to start.
Cheers,
bt
