Visitor jblank
Zynq UltraScale+ Single-Ended and Differential Connections
Hello everyone,
I have a question regarding the Zynq UltraScale+. Take this SoM for example: https://shop.trenz-electronic.de/en/TE0808-04-09EG-2IE-UltraSOM-MPSoC-Module-with-Zynq-UltraScale-XCZU9EG-2FFVC900I-4-GB-DDR4
Is it possible to allocate certain pins to being differential or do you have to allocate the entire I/O bank to being differential? Similarily, if I want to use single-ended signals, does the entire I/O bank have to consist of single-ended signals?
Thank you.
Re: Zynq UltraScale+ Single-Ended and Differential Connections
You may allocate some pins in a bank to be differential and some to be single ended.  You must select IO standards compatible with the bank type (HP or HR) and with teh VCCO powering that bank.
