sigan
Zynq UltraScale+ | Xilinx Power Estimatior (XPE) | Unable to import Vivado 2019.1.2 exported file
Hi, I'm trying to import Vivado 2019.1.2 exported power file to Xilinx Power Estimator (XPE). Nothing happens when I try to import, nothing gets filled in, no error or warning message.
Macros are enabled, so that should be fine I think since the buttons work...
Although some fields in the spreadsheet are not looking fine, Summary -> Power Supply -> Total (A) fields are filled with #VALUE!bilde.png
Does this indicate bad health of spreadsheet?
Setup is as follows:
****** Vivado v2019.1.2 (64-bit)
**** SW Build 2615518 on Fri Aug 9 15:55:25 MDT 2019
**** IP Build 2614745 on Fri Aug 9 20:55:02 MDT 2019
** Copyright 1986-2019 Xilinx, Inc. All Rights Reserved.
Running Office 365 on Windows 10 Pro
XPE spreadsheet: UltraScale_Plus_XPE_2019_1_2.zip from
https://www.xilinx.com/products/technology/power/xpe.html
simon
Hi @sigan
I am also running office 365 and win10. which language is setting?
IMPORTANT: On Windows, make sure your language is set to English. Select Control Panel >Clock,
Language, and Region > Region and Language, and set Format to English.
Simon
simon
Hi @sigan
Can you upload the .xpe for reproducing this issue?
Simon
sigan
Hi @simon , xpe files exported from Vivado 2019.1.2 are attached.
Thank you so much for looking into this!
simon
Hi @sigan
I can see the power number for each, please see the attached XPE
Simon
sigan
Hi @simon, I opened the spreadsheet attached and I still get the "#VALUE!" in the "Total (A)" column in the "Power supply" section of the Summary sheet and I
still cannot import exported data from Vivado 2019.1.2 tool into the XPE spreadsheet. So I think there is some kind of issue with the settings of my Office 365
and the spreadsheet causing it to not operate properly. I want to get to the bottom of this so we can export design data from Vivado and import into XPE without
any hassel in the future.
Are you running Office 365?
Are there any other settings in Excel I should be aware of other the the "Allow all macros" mentioned on the XPE web page: https://www.xilinx.com/products/technology/power/xpe.html
Other things I have tried without any luck:
i) Tried running on my secondary work machine, that is Windows 7 & Excel 365.
ii) Tried deleting all .exd files on C drive, https://www.xilinx.com/support/answers/63366.html
iii) Tried debugging the excel cells that are showing "#VALUE!", but they are password protected. According to Microsoft (https://support.office.com/en-us/article/how-to-correct-a-value-error-15e1b616-fbf2-4147-9c0b-0a11a20e409e)
the "#VALUE!" "The error is very general, and it can be hard to find the exact cause of it."
Is there any way I can be provided with the spreadsheet password so that I can try to pinpoint more accurately what the problem is?
simon
Hi @sigan
Simon
sigan
Yes, setting format to English makes the spreadsheet work. Thanks a lot!
