a_chami
Zynq Ultrascale+ MPSoC V2017.1 - Bank 3[Dedicated]
I have updated my desing to V2017.1 and noticed a new bank on the I/O config. of the Zynq.
This bank is named Bank 3[Dedicated]
Which pins are included in this bank?
Avi Chami MSc
FPGA Site
gnarahar
@a_chami Thanks for the screenshots as I could get which one you referring to.
.Bank 3 corresponds to PS Configuration pins in Bank 503 which are powered off VCCO_PSIO[3]ps_config.JPG
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
gnarahar
@a_chami Can you share the complete Part# of the device you using?
- Giri
a_chami
Hi @gnarahar,
The part number is
xczu9eg-ffvb1156-2-i-es2
Avi Chami MSc
FPGA Site
gnarahar
@a_chami Can you share the screenshot of where you see Bank 3?
- Giri
a_chami
Hi @gnarahar,
This is the screenshot on V2016.4
And this is a screenshot from V2017.1
Avi Chami MSc
FPGA Site
gnarahar
- Giri
