uts
Zynq ultrascale power rail ramp time requirements
Table 11 in ds925 specifies power supply ramp time. Does the 40 ms max mean each rail can take 40 ms to ramp up? Or, does it mean 40 ms max from 1st power rail start to last power rail up?
By referring to the page 10-12 of the DS925, the power supply sequencing order is listed but I haven't found the required timing between these stages. What should be the minimum delay between these voltages?
panantra
Hi @uts ,
--- It means each rail may take min 0.2ms and max 40ms time to ramp from GND to 95% of the Voltage value for that rail.
We do not have any time requirement between power rails.
Just follow the guidelines given in DS925. Refer table no. 37 as well as Table no. 129 for Tpspor and Tpor requirements.
Priyanka
uts
Hi @panantra
Thanks for the information. I am working on a new design with XCZU15EG. I want my power supply to have internal sequencing. Where can I get support?
gnarahar
@uts A general recommendation for power sequence is to power the next power rail after the previous power rail reaches 90% of recommended voltage.
Not sure what you mean by internal sequencing
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
barriet
You may find the reference designs (by device family) useful here as a starting point:
https://www.xilinx.com/products/technology/power.html#partners
Cheers,
bt
