ukonar
how to access zynq in kcu105 ultrascale kit
In  KCU105 Evaluation Board, I'm not able access Zynq "xc7z010GLG225"  through IP block generator in vivado 2015.4.
Can anyone answer how to access the Zynq in KCU105 .
pratham
@ukonar The system controller (Zynq) is delivered as a black-box design that communicates with onboard
programmable devices over an I2C interface. The Zynq-7000 AP SoC system controller IP is
not provided and is not available to end users for modification purposes.
-Pratham
pratham
-Pratham
