Newbie maximminer
how to power ADC block and DAC block
Dear Sir,
If you only going to use one block of DAC and ADC do you still need to connect the power to all blocks?
Will unused ADC blocks still consume power or is there a way to turn them off?
Best regards, Maxim
Re: how to power ADC block and DAC block
All RF ADC and DAC Power pins must be connected to the proper voltage.
The IP will keep unused Tiles powered down.
They will still consume static power.
Use XPE to enable the tile you are using and it will show the static power required
