how to set the schmitte trigger input in kintex-ultrascale+
I'd like to set the schmitte trigger input in  kintex-ultrascale+. For exsampe, RESET input etc. But I don't know how to set the schmitte trigger input .
If  it can set the schmitte trigger input , please tell me how to set  the schmitte trigger input .
Hi @hwtodt ,
Schmitt Trigger input pins were available in old CPLD devices, but unfortunately these do not exist anymore in the new families, such as UltraScale+.
Andre Guerrero
Product Applications Engineer
Hi @hwtodt ,
That option does not exist anymore in any UltraScale or UltraScale+ device.
What is your application? Why do you need a Schmitt Trigger in the input port? Please detail a bit your application so we can try to help you find another solution.
Andre Guerrero
Hi Andre,
Thank you for your reply. My FPGA's application is motion controller of Industrial automation.
This FPGA is replaced the ASIC. The ASIC's system reset signal is a schmitt trigger input.  Because I also want to design the FPGA's reset in the same way.
Best regards,
Hi @hwtodt ,
Andre Guerrero
