how to solve over utilization of uram problem
I had xczu7ev design ,i changed the part number to 4ev and upgraded the  IP to 4ev .It shows the above error when i run the synthesis for xczu4ev-fbvb900-1-i .
Advisor
Advisor
As the error says, target a different part (ie the XCZU7EV). Or modify your design so it doesn't need as much URAM.
sorry but what is it when you say modify ?
The 7EV has almost twice as much URAM as the 4EV. You either must change your design to use less URAM or you must use the larger part.
thank you much.
So, I cant use the design for 4ev .Incase i want to use i have to change the part number?
using less uram means reducing the fpga configuratons?
