fanwei
kcu105 'open_hw_target' failed
 when debug code using JTAG  to device (ku040)  on the KCU105 borad ,hardware Manager can not find the Device...
the TCL Console print the messages:
INFO: [Labtoolstcl 44-466] Opening hw_target vip-pc:3121/xilinx_tcf/Digilent/210308956910
ERROR: [Labtools 27-2269] No devices detected on target vip-pc:3121/xilinx_tcf/Digilent/210308956910.
Check cable connectivity and that the target board is powered up then
use the disconnect_hw_server and connect_hw_server to re-register this hardware target.
ERROR: [Common 17-39] 'open_hw_target' failed due to earlier errors
I has set SW15 to 000000,and no FMC board connected to main board.  sometime it can find ,but in most cases ,it can ont find....
U27,U26 is controlled by 7010,they cause this problem???
gnarahar
@fanwei JTAG is powered off VCCAUX rail. So on your KCU105, "only" LED DS18 is "OFF" ?
If yes, you can try reprogramming the Power Controllers. Check these AR's
https://www.xilinx.com/support/answers/65218.html
https://www.xilinx.com/support/answers/63175.html
- Giri
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
ashishd
Hello @fanwei,
Please check below board debug checklist
https://www.xilinx.com/support/answers/63739.html
If everything is perfect as per 'Switch and Jumper settings' , 'Board Power' and 'Cable detection', then 'JTAG Initialization' is the topic which can provide additional insights to further debugging.
Ashish
fanwei
i found the reason, the power VCCAUX no power cause JTAG discnonnect.occasionally.
the VCCAUX led is not light, and VCCAUX is not power is measured by a multimeter ..
how can i slove this problem?
gnarahar
- Giri
fanwei
other power light is OK, ONLY the vccaux is OFF.
fanwei
yes, only led ds18(VCCAUX) is not light.
