mojc_mos2
limit route of the design to specific region
How can i limit my design to specific region in the same region that exist my IOBs ?
best regards
austin
m,
Easiest way is to use a timing constraint.
Why do you care what the tools do?
Austin Lesea
Principal Engineer
Xilinx San Jose
mojc_mos2
I am using vivado 2015 and zynq-7000 . I am beginer to xilinx. I want limit my design to region that i use idelay/iserdes. How can i do this? Can you say key commands?
austin
m,
You are posting in the wrong place Zynq 7 series is not UltraScale.
You may wish to read::
http://www.xilinx.com/applications/isolation-design-flow.html
and
https://forums.xilinx.com/t5/Implementation/How-to-lock-placement-for-Vivado-design/td-p/517367
Austin Lesea
Principal Engineer
Xilinx San Jose
vemulad
Hi @mojc_mos2
You can use pblocks to restrict the placement of the logic to specific region in FPGA.
Refer to below links
from page-170 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug906-vivado-design-analysis.pdf
and video http://www.xilinx.com/video/hardware/design-analysis-floorplanning-with-vivado.html
Deepika.
mojc_mos2
ok. many thanks for your assistance.
vemulad
@mojc_mos2
Feel free to close the thread by marking the solution.
Deepika.
