bergnoli.infn
mmcm or pll fine frequency tuner
Is it possible to obtain a fine frequency shift of a mmcm or pll output. i.e:
Fin = 100 Mhz
Fout = 100 Mhz + or - 30 ppm?
lowearthorbit
Not that I am aware of,
The way I have done this in the past is to use a direct digital frequency synthesizer (DDFS) asa numerically controlled oscilator (NCO).  One DSP48 may be used which will give you frequency control (lsb) of 3.5E-15.  In effect, the adjustment will appear continuous.
l.e.o.
