Observer rmm
reconfiguring lmk clock with LMX2594ClockConfig
So I initialize my LMX2594 to one clock rate and set up my ADCs/DACs and they all work fine.
However, after I have already initialized it and I want to reconfigure I call LMX2594ClockConfig() again with a new rate, and now when I set my mixer settings they are mistuned (by a ratio of the first clock rate to the second).
Do I have to reset all of my tiles (PG269, page 106-107) in order for the power up sequence to pass the new clock information to the tiles?
Community Manager
Community Manager
Re: reconfiguring lmk clock with LMX2594ClockConfig
Usually we need shutdown and startup the tile if clock setting changed.
Have you ever tried shutdown/startup the tile and can this help make your new setting works fine? I am wondering if this cannot help the new rate work fine that might have some additional settings needed.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Observer rmm
Unfortunately using Xrfdc_Shutdown() and Xrfdc_StartUp() did not help.
Community Manager
Community Manager
Hello @rmm
Sorry for the delayed reply. I was on Vacation for a week.
Have you tried API function XRFdc_DynamicPLLConfig  after you change the LMK2594 output clock with a new frequency?
You can set your new reference clock frequency and sampling clock frequncy with this function and then reset the whole tile.
