ramig972
ultra96-v2 support on vivadio 2019.2,18.04.3 LTS
I'm using Ubuntu 18.04.3 LTS as host, I'm mentioning this as this might be a factor as it's not offically supported but I don't belive its the cause.
I have downloaded and installed the files supporting ultra96v2 from the Avent website to the 2019.2 "boards" file structure.
.....  xilinx/Vivado/2019.2/data/boards/board_files/ultra96v2/1.0>ls -la
total 752
drwxr-xr-x 2 rami rami 4096 Dec 18 17:43 .
drwxr-xr-x 3 rami rami 4096 Dec 18 17:41 ..
-rw-rw-r-- 1 rami rami 83369 Dec 18 17:42 board.xml
-rw-rw-r-- 1 rami rami 243430 Dec 18 17:42 part0_pins.xml
-rw-rw-r-- 1 rami rami 345025 Dec 18 17:42 preset.xml
-rw-rw-r-- 1 rami rami 65188 Dec 18 17:43 ultra96v2.jpg
and ...
/xilinx/Vivado/2019.2/data/boards/board_parts/zynq/ultra96v2>ls -la
total 228
drwxr-xr-x 2 rami rami 4096 Dec 18 18:40 .
drwxr-xr-x 7 rami rami 4096 Dec 19 10:57 ..
-rw-rw-r-- 1 rami rami 104519 Dec 18 18:40 ULTRA96V2.tcl
-rw-rw-r-- 1 rami rami 106639 Dec 18 18:40 ultra96v2_valtest.tcl
and I still do not see the board listed as one of the boards in the "UltraScale" catagory
Any idea?
Best,
RG
sandrao
Community Manager
Community Manager
Hi @ramig972
When you add board files you can set board.repoPaths parameter.
For example I have :
set_param board.repoPaths /home/sandrao/board_repo
This is also documented in this AR : https://www.xilinx.com/support/answers/72033.html
Sandy
Sandy
If starting with Versal take a look at our Versal Design Process Hub , Versal Blogs and the Versal Useful Resources .
