fyq14
vu9p on vivado 2016.3
I have installed vivado 2016.3 in my machine, but I can't find the exact model i am looking for. I am looking for xcvu9p-flgb2104-2-i-es1.
I can only see EVAL boards. Would I require a seperate license to support those boards?
florentw
HI @fyq14,
Yes, the this device require a separated license.
You may need to ask your FAE for the Ultrascale+ Early access lounge access.
Kind Regards,
Florent
Florent
florentw
HI @fyq14,
Kind Regards,
Florent
Florent
selwobevets
This is my first post-might not be in the right place.Anyway, I'm working on a bitstream in Vivado and don't see the part number for the Xilinx VU9P board.  Anybody know what the part number might be?
