xinwei
what is the input clock frequency range for bufgmux
muzaffer
No, being a static cmos device, a bufgmux is capable of sustaining a 0 or 1 as long as it is powered.
ralfk
At a minimum the same as the output frequency or the fastest clock you can get through an I/O.
xinwei
Thanks for feedback.
I found Fmax for bufgctrl in ds893. Is there Fmin?
muzaffer
