zu2 jtag debug error
hi
but
the vivado hardware manager display zu3????
Why does this happen
and i use xsdk debug
please help me .thanks a lot
Re: zu2 jtag debug error
you might want to have a chat with th emanufacturer of the board
https://wiki.trenz-electronic.de/
IMHE. They have a very good tech support.
your Vivado HW Manager shows "dummy_dap" instead of ARM_dap.
So your processing part is crashed.
This is can happens, when you has used wrong PS configuration for your system, when the ZynqMP is hold into reset, when the PS reference clk is missing, when some power is missing....
You should check PS_ERROR_OUT and  PS_ERROR_STATUS if this is possible on your board. See also
https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf
What's the name of your ZynqMP board?
br
John
