taylor91
在VU440 和VU19P上能否实现MIPI DPHY IP?
karnanl
Hello @taylor91
Please kindly remove this post.
I believe, this is the same question as this post ?!
    https://forums.xilinx.com/t5/Video-and-Audio/Can-i-implement-MIPI-DPHY-rx-in-VU440-and-VU19P/td-p/1234164
Kind regards
Leo
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs
Versal Example Designs : LINK
karnanl
Hello @taylor91
Kind regards
Leo
