g9
我在使用wiki的VCU TRD RIO例程,给予的输入是由HDMI,我期望通过USB摄像头输入。此例程参照VCU TRD设计,在VCU TRD设计中似乎已经设计配置好了USB摄像头输入,若我使用此VCU TRD RIO的设计不知道是否还需要在vivado中对USB摄像头输入重新修改配置
watari
Professor
Professor
Hi @g9
If your usb device has capability of v4l2, you can achieve what you want to do by changing v4l2 node.
Would you make sure capability by gst-device-monitor-1.0 or v4l2-util ?
Hope this helps.
Best regards,
g9
感谢您以上的回答   我想询问如果我想上述这样在此例程上实现的USB采集和HDMI显示,我是否需要在HDMI output的硬件层面上做出修改
watari
Professor
Professor
Hi @g9
What do you mean this ?
Is your query how to change parameter on DRM ?
If so, would you make sure capability of HDMI monitor and change parameter by modetest command ?
Hope this helps.
Best regards,
