jmcm
12-bit per component Gamma Correction LUT
Xilinx has a Gamma Correction IP supporting up to 12-bit per component (PG004).which is now discontinued.
It is being replaced by the LogiCore Gamma LUT (PG285) which only goes up to 10-bit per component.
Does this mean that a Gamma LUT with 12-bit per component is not provided any longer?
Regards.
Jmcm
florentw
HI Jacques,
Do you have any update on this? Were you able to write you own IP with HLS?
Thanks and Regards,
florentw
Hi @jmcm ,
Yes your understanding seems correct.
If 12-bit support for gamma correction LUT is a requirement for you, I encourage you to contact your FAE about this to see if this can be implemented in future releases.
jmcm
Hi Florent,
Yes, 12 bits per component, 2 pixels per clock, 300MHz.
Jacques
florentw
HI @jmcm
Then please contact your FAE about this.
jmcm
Hello Florent,
I started on the design of the LUT as I need to progress in my project.  I am using 3 xpm_memory_tdpram with a read latency of 1 made out of ultra-rams to get 2 pixels per clock.
The axi-lite interface to program the LUTs is straight forward.  But I'm having problems with the axi-stream master and slave interfaces.
One way maybe to do this is to duplicate the URAMs to avoid creating bubbles in the stream but I would rather stay with 3 if possible.  Could you please point me to some docs or template codes to do this if there is any.
Jacques
florentw
Hi Jacques @jmcm
Did you consider using HLS for this? What I found great with this is that you do not have to really care about the AXI4-Stream interface. You just say "read or write" data. It might save you same headhache
I made an example of video IP as part of my video series: Video Beginner Series 17: Create a Video Crop IP using HLS (part 1) and Video Beginner Series 18: Create a Video Crop IP using HLS (part 2)
jmcm
Thanks Florent,
I'll look into it.
Jacques
florentw
HI Jacques,
Thanks and Regards,
jmcm
Hello Florent,
I was able to write a verilog module to handle this.  I will try HLS when I have more time.
Jacques
