2 MIPI CSI-2 Rx Subsystem IP in the same HP I/O bank
Hi Team,
We are using 2 MIPI CSI-2 RX Subsystem IP in the design targeting xczu7cg-fbvb900-1-e device and vivado version is 2019.2.
Both the IPs are in the same HP bank(Bank 64). We have tested the design with both the IPs in 800Mbps line rate and we are not finding any CRC or ECC errors. The number of lines and pixels are constant as expected.
But when we try testing in higher line rates(2000Mbps), we are getting CRC and ECC(2 bit) errors and also the number of lines and pixels are not constant.
Before checking the hardware for the above errors, I just want to make sure that the configuration of IP in the GUI is proper.
And also I want to know is there any consideration when use 2 MIPI IPs in the same HP bank.
I have attached the pin configuration of the 2 MIPI IPs.
have also attached the .xci files of the 2 MIPI IPs and bd.tcl for the block diagram of the design.
Do we need to connect clkoutphy_out signal in the design. Currently this is not connected anywhere in the design
Please let me know if there any changes needs to be done in the IP settings and the block diagram for the higher line rates.
With regards,
Thejashree
Hello @thejashree_13
I do not see any issue on the MIPI CSI-2 RX IP setting.
For line-rate above 1500Mbps, please enable Deskew pattern feature on your sensor.
Could you please check AR#73209 ?
The length of the periodic deskew pattern sent by the transmitter should match the requirement of the receiver side.
Xilinx MIPI D-PHY RX deskew algorithm requires a minimum of 8192 UI (or 1024 rxbyteclockhs) of periodic deskew-pattern to do calibration correctly. Please confirm that your sensor is configured correctly.
No, since your IP is configured as "Include Shared Logic in core"
Leo
Leo
Hi @karnanl ,
Thank you so much for the response.
After configuring the sensor for the proper TSKEWCAL value its working fine at the higher line rates.
With regards,
Thejashree
That's good to hear. Thanks a lot for the update.
Leo
