4K Video transmission using Zynq Ultrascale+ MPSoC
I recently came across one video from Xilinx, in which they have used Zynq Ultrascale+ MPSoC for 4k video transmission and reception. I want to replicate this project. Any help in this context will be much appreciated.
Nitin Kumar
@Nitin_Kumar
I think the video is talking about VCU TRD Multistream design : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/541786229/Zynq+UltraScale+MPSoC+VCU+TRD+2020.1+-+VCU+TRD+Multi+Stream
One of the stream is captured from MIPI camera through framebuffer+PS DDR
@Nitin_Kumar
Which Video did you watch? HDMI FrameBuffer example design supports 4k video transmission and reception : https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842753/HDMI+FrameBuffer+Example+Design
If you are not Linux user, you can refer to chapter 6 of https://www.xilinx.com/support/documentation/ip_documentation/v_hdmi_rx_ss/v3_1/pg236-v-hdmi-rx-ss.pdf, and then generate the passthrough example design with Bare-metal driver.
hello @xud ,
Thank u for your response, I watched this, "New video: Simultaneous 4K video encode/decode over IP using Zynq UltraScale+ MPSoC supporting as many as 8 streams," available at https://forums.xilinx.com/t5/Xcell-Daily-Blog-Archived/New-video-Simultaneous-4K-video-encode-decode-over-IP-using-Zynq/ba-p/800953.
Thanks for sharing the link, I don't have HDMI IP, so I am working with MIPI CSI.
Nitin Kumar
Also I want to transfer data from MIPI Rx subsystem to PS DDR via Frame buffer/VDMA, I want to know the math behind it. Like how to calculate the data rate for different configurations 1,2,3,4 lane Raw8,10,12, how to calculate the bandwidth and also to know whether this bandwidth will be supported by DMA or not. Any link to this will be really helpful.
@Nitin_Kumar
Hello @xud , sorry for late reply. Thanks for sharing the link and information.
I saw the link that you shared. As you may see that all of these pipelines, converts raw data to RGB and does some processing before dumping data into PS DDR, and also frame buffer does not take raw input. I want to do some ISP before converting raw data into RGB, hence require data directly from MIPI Rx subsystem into PS DDR. And after doing ISP do some more processing in PL using demosaic/GammLUT correction etc.
Can you suggest some design/example/tutorial for this?
Nitin Kumar
Hello, were you able to get the project working? Also, did you use an OS?
Thank you
Hello @joe306 , No I did not try to execute this project as I don't have ZCU102 board, also I am only interested in using MIPI CSI interface. There are other designs available from Mr.Adam Taylor involving MIPI but he uses RGB data (MIPI to Demosaic,GammaLUT) and transfers that into PS DDR, although he has given solutions both with and without OS. My solution requires raw data in PS DDR.
Nitin Kumar
Hi @Nitin_Kumar
Can you use linux OS ?
If yes, would you use GStreamer and v4l2src element to store video stream into PS DDR ?
Also, you can see example if you saw @xud 's suggested URL.
Best regards,
Hello @watari , My question was more intended towards Hardware development(Vivado pipeline), but yes I intend to use create platform and Linux OS image using .xsa container from Vivado. Also, I am using Gstreamer and v4l2 packages during platform generation, but I am just following few tutorials and don't exactly know the purpose of all the packages that are being used. I have just started learning and using FPGA/Xilinx tools.
Probably if you can illuminate the topic by sharing your knowledge, it will be very useful for newcomers like me.
Nitin Kumar
Your project sounds very interesting. I'm working with SDI Video and CoaXpress Video. I will be interfacing with video cameras and then I will do video overlay and meta-data insertion. Would you be willing share your IP Integrator Block Design? Maybe convert it to TCL for regeneration or convert it to pdf?
Respectfully,
Joe
Hello @Nitin_Kumar
PS-DDR question should be posted on embedded board rather than Video board here. You will have better response from embedded users.
First, Could you please check the following AR ?
https://www.xilinx.com/support/answers/70413.html
I believe you need to use AXI-DMA to transfer AXI4-stream data from PL to PS-DDR.
This AR will show you an example how to use AXI-DMA IP.
Some of Xilinx TRDs also using AXI DMA in the design. For example :
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/520618122/Zynq+UltraScale+MPSoC+Base+TRD+2020.1
Leo
Thanks @karnanl ,
     Yes I need to use AXI-VDMA or Frame Buffer to transfer data from PL to PS-DDR, my confusion was if raw data could be transferred or not as most of the examples involve some video processing before pushing data into DDR. But my doubt is clear now, frame buffers can be used to push Y data(raw) into DDR.
Thanks for your answer.
Nitin Kumar
Thank you very much for posting your comments. I will be working with video soon and this will be helpful. Respectfully, Joe
@joe306 I regret that I can't share the vivado pipeline with you right now, as I am still working and it is not yet developed.
Nitin Kumar
That's okay. I'm glad others are doing fun stuff. Respectfully, Joe
