4ev board can not encode 4k60fps yuv422 video stream with ctrlsw_encode command
I want use ctrlsw_encode command to encode 3840*2160 60 fps video stream , here is my cfg file :
#                          Configuration file
[INPUT]
# YUVFile : YUV input file
YUVFile = 4k.yuv
# Width, Height: frame width/height in pixels
# width and height shall be multiple of 8 pixels
Width  = 3840
Height = 2160
# Format : FOURCC format of input file
# typical file formats       : I420, I422, I0AL, I2AL...
# hardware supported formats : NV12, NV16, P010, P210... (depends of the hw ip)
# default value : I420
Format = NV16
[OUTPUT]
# BitstreamFile : elementary stream output file
BitstreamFile = bitstream.hevc
# RecFile : optional output file for reconstructed pictures
#RecFile = rec.yuv
[RATE_CONTROL]
# RateCtrlMode : selects the bit rate control mode
# allowed values : CONST_QP, CBR, VBR, ...
# default value  : CONST_QP
RateCtrlMode = CBR
# FrameRate : number of frames per second
# default value : 30
FrameRate = 60
# BitRate: target bitrate in kbit/s (not used when RateCtrlMode = CONST_QP)
# default value : 4000
BitRate = 10000
# MaxBitRate: maximum bitrate in kbit/s used when RateCtrlMode = VBR
# MaxBitRate shall be equal to BitRate when RateCtrlMode = CBR or LOW_LATENCY
MaxBitRate = 100000
# SliceQP : Quantization Parameter
# when RateCtrlMode = CONST_QP, it defines the QP for all slices, otherwise it specifies the initial QP
# allowed values : from 0 to 51, AUTO
SliceQP = 30
# CPBSize : specifies the size of the Coded Picture Buffer as specified in the HRD model, in seconds (not used when RateCtrlMode = CONST_QP)
# default value : 3.0
CPBSize = 1.0
# InitialDelay : specifies the initial removal delay as specified in the HRD model, in seconds (not used when RateCtrlMode = CONST_QP)
# default value : 1.5
InitialDelay = 1.0
[GOP]
# GopCtrlMode : specifies the Group Of Pictures configuration
# allowed values : DEFAULT_GOP, LOW_DELAY_P, LOW_DELAY_B, PYRAMIDAL_GOP
# default value  : DEFAULT_GOP
GopCtrlMode = DEFAULT_GOP
# Gop.Length : GOP length in frames including the I picture. 0 = Intra only
Gop.Length = 60
# Gop.NumB : maximum number of consecutive B frames in a GOP (used only when GopCtrlMode = DEFAULT_GOP or PYRAMIDAL_GOP)
# allowed values : 0 to 4    when GopCtrlMode = DEFAULT_GOP
#                  3, 5 or 7 when GopCtrlMode = PYRAMIDAL_GOP
# default value  : 0
Gop.NumB = 4
# Gop.FreqIDR : minimum number of frames between two IDR pictures (IDR insertion depends on the position of the GOP boundary)
# allowed values : positive value or -1 to disable IDR insertion
# default value  : -1
#Gop.FreqIDR = 25
[SETTINGS]
# Profile : specifies the standard/profile to which the bitstream conforms
# allowed values : AVC_BASELINE, AVC_MAIN, AVC_HIGH, AVC_HIGH10, AVC_HIGH_422,
#                  HEVC_MAIN, HEVC_MAIN10, HEVC_MAIN_422_10...
# (Some profile might not be supported by your hardware ip, see hardware ip specification)
Profile = HEVC_MAIN_422_10
# Level : specifies the level to which the bitstream conforms
# allowed values : 1.0 to 5.2 for AVC, 1.0 to 5.1 for HEVC
Level = 5.1
# Tier : specifies the tier to which the bitstream conforms (HEVC only)
# allowed values : MAIN_TIER, HIGH_TIER
#Tier = MAIN_TIER
# ChromaMode : selects the chroma subsampling mode used to encode the stream
# allowed values : CHROMA_MONO, CHROMA_4_2_0, CHROMA_4_2_2
# default value  : CHROMA_4_2_0
ChromaMode = CHROMA_4_2_2
# BitDepth : specifies the bit depth of the luma and chroma samples in the encoded stream
# allowed values : 8, 10
# default value  : 8
BitDepth = 8
# NumSlices : number of row-based slices used for each frame
# allowed values : from 1 up to the number of coding unit rows in the frame
# default value  : 1
NumSlices = 4
# QPCtrlMode : specifies how to generate the QP per coding unit
# allowed values : UNIFORM_QP, AUTO_QP, LOAD_QP, LOAD_QP | RELATIVE_QP
# default value  : UNIFORM_QP
QPCtrlMode = UNIFORM_QP
# ScalingList : specifies the scaling list mode
# allowed values : FLAT, DEFAULT, CUSTOM
ScalingList = FLAT
# EntropyMode : selects the entropy coding mode (AVC only)
# allowed values : MODE_CAVLC, MODE_CABAC
# default value  : MODE_CABAC
EntropyMode = MODE_CABAC
# LoopFilter : enables/disables the deblocking filter
# allowed values : ENABLE, DISABLE
# default value  : ENABLE
LoopFilter = ENABLE
[RUN]
# Loop : specifies whether the encoder should loop back to the beginning of the YUV input stream when it reaches the end of the file
# Allowed values : TRUE, FALSE
# default value  : FALSE
Loop = TRUE
# MaxPicture : number of frames to encode
# Allowed value : ALL, 1 .. 2147483647
# default value : ALL
MaxPicture = 300
# FirstPicture : specifies the first frame to encode
# Allowed value : 0 .. 2147483647
# default value : 0
FirstPicture = 0
but , the results show that it's only 51fps. how to modify cfg file to achieve 60fps
Re: 4ev board can not encode 4k60fps yuv422 video stream with ctrlsw_encode command
Hi @singlee
What tool do you use to check the final frame rate?
Can you share the bitstream.hevc you are getting?
Florent
Mentor
Mentor
Hi @singlee
I'm confusing about your configuration file.
Because it is inconsistent for color (bit) depth.
Why do you choose profile as HEVC_MAIN_422_10 even if bitdepth is 8bit ?
I suggest to make sure color depth.
Best regards,
Hi @singlee
Do you have any update on this?
Aoife
Thank you for replay.
I notice that the hardware ip cannot support H264 YUV422 8BIT (I'm not sure for that) , so i change it to h264 yuv422 8bit ;
Here is my new configuration.
[INPUT]
YUVFile = 4k.yuv
Width  = 3840
Height = 2160
Format = NV16
[OUTPUT]
BitstreamFile = /dev/null
#RecFile = rec.yuv
[RATE_CONTROL]
RateCtrlMode = CBR
FrameRate = 60
BitRate = 4000
MaxBitRate = 40000
SliceQP = 51
CPBSize = 1.0
InitialDelay = 0
[GOP]
GopCtrlMode = LOW_DELAY_P
Gop.Length = 30
# default value  : 0
Gop.NumB = 0
Gop.FreqIDR = 60
[SETTINGS]
Profile = AVC_HIGH_422
Level = 5.2
#Tier = HIGH_TIER
# default value  : 8
BitDepth = 8
# default value  : 1
NumSlices = 4
ScalingList = DEFAULT
LoopFilter = ENABLE
[RUN]
Loop = TRUE
MaxPicture = 300
# default value : 0
FirstPicture = 0
Result shows just 37fps:
root@vcu_uz7ev_cc:/home/work# ctrlsw_encoder -cfg encode.cfg
Allegro DVT2 - AVC/HEVC Encoder Reference Software v1.0.41 - Copyright (C) 2018
Confidential material
  Encoding picture #299    - Flushing...
Achieved bitrate = 0.0000 Kbps
300 pictures encoded. Average FrameRate = 37.5704 Fps
The ctrlsw_encode command output statistical results.
Mentor
Mentor
Hi @singlee
You have to concern the following parameters without contradiction.
- Format
- Profile
- BitDepth
Especially, NV12 and NV16 is for 8bit color depth.
If your input color depth is 10 bit, you must use P010 or P210.
NV12 = YUV 4:2:0 8bit
NV16 = YUV 4:2:2 8bit
P010 = YUV 4:2:0 10bit
P210 = YUV 4:2:2 10bit
https://docs.microsoft.com/en-us/windows/win32/medfound/10-bit-and-16-bit-yuv-video-formats
Best regards,
My bitstream is 8Bit. and i change my configuration file to :
    Format = NV16
    BitDepth = 8
In my opinion, HEVC_MAIN_422_10 is higher profile, it should be compatible lower profile(such as 422 8bit , cause i can't find that profile, so i use 422 10bit instead of it ). Can this hardware ip encode YUV422 8Bit bitstream to h265 stream ? If it can do, Which one should I choose ? Or can i encode to h264 stream with 60fps ? The result shows h264 have lower fps than h265.
